Connect Nest Hello replacement
Micky3333
Got a replacement Nest Hello.  Wired. Replaced old one.  Ring is lit blue.  Cannot connect to Google home.
@Micky3333
If you have a Google Nest Hello Doorbell, you need to set it up in the Google Nest app, not in the Google Home app.  Once you set it up there, you will be able to view it in the Google Home app, but administration and notifications will still be done in the Google Nest app.
MplsCustomer, I appreciate your help here.
Micky3333, I want to make sure you're all good. Have you tried the steps shared by MplsCustomer? — how did the steps go? Check out this guide: Install Nest Doorbell (wired).
Let us know if you need more help.
janthadeus
Hi Micky3333,
How's it going with your Nest Hello doorbell? Still need our help?
aatienza
Hey Micky3333,
I appreciate the help, JT.
Archie
