01-29-2022 07:22 AM
I have screwed my base plate into the wedge. However, I can’t tighten the base plate sufficiently. The base plate is a bit loose, and I have screwed the screws in as tightly as I can.
02-04-2022 02:01 PM
Thank you for your patience. If you are seeking a replacement, please first fill out this form so we can collect some important information from you. Once the form is submitted, you will have your case number. Please be aware that this thread will be locked.
