07-30-2022 12:04 PM
I had my cam w/floodlight installed (wired) but the electricians accidentally threw out the box. Now I can’t connect my device to my network as I have no code (first time setup). What can I do?
07-30-2022 05:13 PM
According to the installation video here: https://support.google.com/googlenest/answer/11003780?hl=en, at 1:18 on the video, you should be able to use the 6-character setup code at the bottom of your floodlight camera.
08-02-2022 04:42 AM
Thx. Yes, finally figured it out (as video was not clear) that you need to remove the wire under the camera to see the code. Thx for your reply
07-30-2022 05:13 PM
08-02-2022 04:42 AM
08-04-2022 08:41 AM
Best regard,
08-07-2022 05:58 PM
Thanks for your assistance, MplsCustomer and Brad.
Dbruce, sounds good! I'm glad to know that your Nest Cam with Floodlight is already up and running! Please let us know if you still need help as we will be locking this in 24 hours if we won't hear back from you again. Feel free to start a new thread and we'll be happy to help.
