Discontinue HUB QR code from camera and use NEST QR
gailweeker
We bought a NEST Outdoor Camera and accidentally used the HUB QR code, but we do not want HUB. How can we uninstall HUB and use the NEST QR code on the camera?
2 REPLIES 2
EmptyNester
Silver Product Expert
In the setting in the app you should be able to "remove" the device and then re-add it correctly
maedacortez
Hi gailweeker,
Thanks for reaching out. I understand you need to set up your Nest camera with a QR code. I'm happy to help!
If you can see your camera set up in the app, first remove it and follow these steps:
If using the Nest app:
  1. Open the Nest app.
  2. Tap Menu in the top left corner.
  3. Select the home you want to remove.
  4. Tap Settings > Home info > Leave home > Leave.
If using the Google Home app:
  1. Open the Google Home app.
  2. Tap Favorites or Devices.
  3. Tap Settings > Remove device > Remove.
After removing it, try re-adding your camera and you will see the QR code option again.
I hope this helps!
Manuel
