12-10-2022 12:56 AM
Not sure if I’ve put this in the right category, but my Nest Doorbell (wired) has suddenly gone offline. It was working earlier, but when I went to go to bed I got a notification saying it’s offline. I’ve tried to troubleshoot it myself, but none of the attempts have worked.
All my other cameras are online and working, and if I ring the doorbell it’s working fine too. Just not the camera. Not quite sure what my next steps are, besides calling out ADT (did all my installation) to see if they can get it to work.
12-15-2022 08:59 AM
12-17-2022 08:56 AM
was talking to support through chat but lost them, need assistance
12-18-2022 05:43 PM
I’m sorry for the trouble here. Let’s sort this out — a few questions: what’s the voltage of your transformer? How’s the temperature of the doorbell (warm, hot, cold or normal)? What country are you located in? Has there been any recent power outage in your area? Also, has it been exposed to direct sunlight?
Here are some troubleshooting steps you can try:
Important: When the doorbell shows a blue pulsing light when connected to a computer, it means it’s working. They may be issues on your wires or transformer. I recommend scheduling a visit with our partnered Nest Pro.
I appreciate your help here, Brad.
12-21-2022 06:07 PM
It's me again. I want to make sure you're all good — did those steps work?
12-22-2022 06:37 PM
I appreciate the help, JT.
Archie
