12-30-2021 10:01 PM
I can view the camera if I tell my nest hub to see the front doorbell and I get the notifications to my phone but my google nest mini and nest hub will not chime or show me who's at the door (the whole reason I have either)
I am on battery and it says electronic chime does not work on battery but also in the description of the device it says it will work on battery with the nest hub.
Thanks in advance
12-30-2021 10:20 PM
I am having the same problem with a wired doorbell. It used to work.
03-30-2022 09:23 AM
I apologize for my late response and thank you for all of your patience while waiting for a reply. I definitely understand how frustrating your situation must be, and I wanted to make sure that your concern was acknowledged. It is correct that there is no Chime required, but the Nest Doorbell (battery) doesn't work with a chime unless you have a smart display/speaker to use with it.
04-04-2022 01:53 PM
Just checking in to see if you still need assistance with this issue. We'll leave this topic open for another 24 hrs in case there are any follow up questions or comments. Please let me know if you need further assistance.
04-14-2022 09:19 AM
Hey Folks.
