11-23-2022 09:56 AM
Recently upgraded our modem and kept same user ID and password. Now doorbell is offline.
11-23-2022 10:29 AM
Did you mean you kept the same network name (SSID) and Wi-Fi password? If you did, that would seem to be enough. (See the link at the bottom.)
Perhaps the doorbell also needs to be restarted in order to reconnect. We have the older Google Nest Hello Doorbells, but when we have had minor issues (rarely), I've turned the doorbells' electrical circuit breaker in our circuit breaker box off and on just to force the doorbells to restart. I suppose you could also try these instructions for using the reset pin to restart (not factory reset) your doorbell: https://support.google.com/googlenest/answer/9252162?hl=en#zippy=%2Cnest-doorbell-nd-gen-wired
These are guesses on my part, as we don't have the 2nd gen doorbell. Can you still see the doorbell in the Google Home app?
These are Google Nest's instructions for changing Wi-Fi:
11-27-2022 05:45 PM
Checking in — have you tried the suggested steps provided by MplsCustomer? If so, how did it go? Let me know if you need more help.
11-30-2022 06:21 PM
Hey Kschoen2,
12-01-2022 06:49 PM
I appreciate the help, JT.
Archie
