03-19-2024 04:20 PM
I want to replace the existing doorbell with a wired Nest doorbell. The current doorbell isn't on the door, but on a wall to the left of the door. Will the camera work if it's mounted to the left of the door?
03-19-2024 06:33 PM
Yes, but you will get a side view of the doorway area.
03-19-2024 07:38 PM
Do you think using a mounting device like this one would work? Doorbell Mount from
Doorbellmount.com
03-20-2024 05:19 AM
I don't know. It LOOKS more suitable for a Ring doorbell.
03-20-2024 09:29 AM
Thanks for hanging in there and helping answer my questions. The Doorbell Mount site has a long list of doorbell cameras to choose from so I think it would fit, but they're made on a 3D printer so maybe not the most elegant look.
Amazon has a black plastic plate to cover the hole left from the original doorbell as well as an additional angle wedge product. Those might do the trick a bit more subtly.
Wasserstein Angle Wedge
Minneapolis is my home town! (Go Gophers!) Thank you for helping me with this. It's a small thing, but I think doing it right will make a big difference. Cheers!
