04-22-2024 08:15 PM
Volume is very low, how to increase the volume
04-23-2024 10:51 AM
Which volume are you referring to? The volume on the doorbell itself cannot be set or changed. If your doorbell is wired and you're using the "Indoor chime" option, the volume on your indoor doorbell chime depends on your indoor doorbell chime. If you're using the "Visitor announcements" option, the volume depends on the current volume your Nest speakers. And notifications on your iPhone depend on the current volume on your phone and on whatever sound you've configured under Settings | Sounds & Haptics | Default Alerts.
