Doorbell white pulsing light never turns blue
mircea
After I have changed my router and I had to disconect all may cameras (2 cameras and a doorbell) now I am unable to connect any of them.
The light never turns blue and if I try to connect with the light pulsating white, I get to the point "connecting to joining device" and then fails.
After I read other post here, I factoy reset all of them -> same problem. I created another home -> same problem.
How can it be possible that after a simple change in wifi I can no longer use any of my google products (a few monts old)???
Any solution?
mircea
Actually I was doing only a "restart" and not a "factory reset". After the factory reset, I managed to reconect the doorbell.
JI am relieved to hear that your doorbell is reconnected! Just checking in to see if you still need assistance with this issue. Please let me know if you need further assistance.
Hey Folks.
