12-30-2021 08:00 PM
It’s a google nest doorbell wired and I tried the factory reset
press the reset and button for 10 seconds at the same time etc. except all it is doing is blinking green above the camera. I unplugged it, re wired to make sure no loose connection and nothing. What’s the next step after the attempt to factory reset
01-22-2022 04:47 PM
The same thing happened to me. Unfortunately, after a year of troubleshooting, Google concluded that the problem was a hardware issue and needed to replace my doorbell. I bought the doorbell brand new in 2019, and sadly it only lasted two years. I recently purchased a new Nest doorbell and have no issues thus far.
01-25-2022 03:43 PM
02-20-2022 06:02 AM
Hey Brad. This is the same post that's on every other Nest doorbell won't reset thread. It doesn't address or answer the problem. I have tried a soft reset and a factory reset and it still just shows a blinking green light at thetop and the doorbell doesn't work. Is this a hardware problem? And before you tell me you understand how frustrating this must be, I've read that thread. Give me an answer/solution.
