11-30-2021 08:46 PM
Night vision is not working, set on Auto. Turned off then back on. Nothing. Hasn't worked in days. As soon as it got dark, ot used to change. Now nothing.
12-01-2021 04:29 AM - edited 12-01-2021 04:30 AM
That happened to me, but I noticed that there was a reflection that the night vision bounced off of, causing it to dim (basically turns down the balance) automatically. Look for any bright object, porch light, white wall/ceiling, downspout, etc. that might be causing it to remain dim (black). Make sure all your settings are correct and you have cleaned the sensor as well.
01-20-2022 03:30 PM
Just wanted to jump in here to check to make sure that you saw the response from BG. Shoutout and huge thank you to BG for the help here. Please let us know if you have any other questions or concerns.
Garrett DS
01-25-2022 03:54 PM
01-27-2022 09:17 AM
Hey Folks.
