01-11-2022 02:27 PM
I bought this new doorbell wireless setitup no problem then time came to recharge.
I did.
App says reinstall to ...
Failure all the time - so
did a restart- did not work
Did factory reset- did not work
Reboot modem, wifi... then used another phone to reinstall- did not work
Always same issue.
I install once then app say everything good, I unplug doorbell, doorbell say fully charged reinstall to connect and when I try to reinstall, nothing happen
02-15-2022 10:08 AM
Thank you for your patience. I believe that you have a faulty device. My suggestion would be to get it replaced. Please first fill out this form so we can collect some important information from you. Once the form is submitted, you will have your case number. Please be aware that this thread will be locked.
01-18-2022 09:03 AM
02-12-2022 09:15 AM
Yes, I still need help.
The doorbell is on the shelve since
02-15-2022 10:08 AM
