Fixing water in Nest Camera lens
Harvey1958
 I was able to remove the 3/4" lens by gently working the tip of an exacto knife around the seam.  You'll discover where the seal failed as the water inside will start weeping out.  Focus the tip there, trying to get the knife tip under the glue gap on the edge and then work around the circumference until enough of it is free to pull it loose of the failed adhesive.  The key step is finding that one place where the water will leak out, and working your exacto blade tip in.  Try twisting the blade  as you gently lever the lens free.
I'm using a bit of silicone seal to reinstall it after I'm sure it's totally dry.
Update: I sealed in the lens, powered it up and the lens promptly fogged up.  Had to dig the lens back out before the sealant dried.  Have powered the device up lens free in a protected location and will leave it there several days before revealing.  It's producing a perfect image but led is red.
Update 2:  Even after leaving the thing in a bag of rice for a week, and letting it sit in the hot sun, I still got some light fogging after resealing and powerup.  Fortunately it was very light, just around the outer periphery and after a day of operation finally cleared up.  While that's good news, probably means the unit is not 100% water tight, and might refill again, next rain.  Rain is forecast for this Weds, so I'll update accordingly.
janthadeus
Hi Harvey1958,
Thanks for posting and I appreciate your time in providing the Community the steps cleaning the camera lens — it's a big help. Could you fill out this form and let me know once you’re done?
janthadeus
We haven't received your form. Were you able to fill it out? Do you still need help?
Harvey1958
There isn't a form to complete at that link provided. It's a very general search page.
janthadeus
Oops! My bad. Could you try it again and let me know once you're done?
janthadeus
Hello there,
We got the form you've submitted — thanks for filling that out. I'll consider this post as complete and will lock the thread in 24 hours. Please keep an eye on your email as someone from our team will reach out to you to assist you further.
