03-31-2022 04:26 AM
The light from my Nest floodlight cam suddenly disappeared from Google home. This has happened since before but I still can’t find an explanation as to why. Does anyone have any thoughts. I’ve read through the similar posts but there doesn’t seem to be an answer.
04-04-2022 01:14 PM
04-04-2022 02:24 PM
I did a manual reset on the camera attached to the device and it seems to work now. This is the second time this has happened and I don’t see any pattern. Can you please explain why this happened and what I can do to prevent it from happening again?
04-05-2022 10:52 AM
I am relieved to hear that it's working now, but as for what causes it, It's probably a bug. I don't have any updates on it, but once I do, i'm sure our customers will know.
04-05-2022 12:57 PM
This has been reported multiple times. Your answer is not helpful.
04-05-2022 02:50 PM
Regardless if its been reported several times, I still do not yet have an update to provide. Thank you for your feedback.
04-08-2022 07:25 PM
I’ve had my floodlight replaced because a manual reset wouldn’t fix it. Now the new floodlight is having the same issue. Google engineers need to come up with a solution and provide everyone who bought one a solution. If there is no solution a refund for all is in order. This is very frustrating. I thought I got a lemon but now it’s happening again. A none answer has been Google’s answer for many months now. It’s time for a real answer.
05-04-2022 08:57 AM
@Vette2
If you need anything else, please let me know.
05-19-2022 09:11 AM
Hey Folks.
