10-31-2024 07:24 PM
Hello I have a battery error and it’s no longer working. How do I rectify this issue? I didn’t know there was a battery. Thanks in advance
11-01-2024 08:43 AM
The floodlight fixture actually uses the Google Nest Battery Camera, which we've had for over 3 years, plugged in with the optional power cable.
One possibility to check is whether you have a good connection where the power cable plugs into the base of the camera. Another thing to check is whether--if your floodlight camera is on a circuit with a switch--that you have that switch turned on at all times. If you have a good connection and have continuous power all the time, your camera should be running on household current and the battery SHOULD not deplete. Our camera has been "Live" and online since Sept. 2021 and the battery has never depleted.
If that doesn't help, you could try contacting Support:
