12-29-2021 12:45 AM
Yesterday I installed my Goole Nest Cam en Doorbell (battery). I started with the Cam which works perfectly. I got history, face recognition, detection zones etc. During the installation process of the Cam I got the walkthrough to get Nest Aware trial as well (which I activated).
After that, I installed the Nest Doorbell (the new version on battery) but I installed it wired so that it has continuous power, which is shown in the Home app as well (via an infinite symbol on the battery screen). However, I can't access my history for the doorbell nor does it recognise faces and I can't set any alerts for the detection zones. I can create a zone, but the alert section is empty to select which alerts I want.
When I go to the Nest Aware section in the Home app (Gear icon -> Nest Aware) the only camera added there is the Cam. First I thought that I might have to do with the trial, so I got the paid Nest Aware basic plan for a year. Still, the doorbell seems to be functioning as if it is without a Nest Aware subscription (only live feed, no history and alerts except for ringing the bell). I thought that one Nest Aware subscription covers all the Nest products in one home.
Could it be that the doorbell didn't get recognised/added to Nest Aware after installation? Any tips on how to fix this?
Cheers!
12-29-2021 08:39 AM - edited 12-29-2021 08:39 AM
Unfortunately, you can't get continuous 24/7 video history with the new Google Nest Doorbell (Battery) even if it is wired, per Google. (I'm just another customer.)
"**24/7 video history is only available for wired Google Nest cameras and Nest Doorbell (wired). Not available for Nest Doorbell (battery), even with optional wired installation."
03-24-2022 08:43 AM
I apologize for my late response and thank you for all of your patience while waiting for a reply. I definitely understand how frustrating your situation must be, and I wanted to make sure that your concern was acknowledged. I am afraid that @MplsCustomer is correct, 24/7 feed is not available as it draws too much power. It would be specific to event-based footage. You can still purchase the Nest Hello Doorbell (wired) if you would like that feature.
03-28-2022 10:14 AM
Just checking in to see if you still need assistance with this issue. We'll leave this topic open for another 24 hrs in case there are any follow up questions or comments. Please let me know if you need further assistance.
03-29-2022 10:20 AM
Hey Folks.
