Google Nest battery cam won't reset. Shows offline/unavailable.
jonrrunge
My Google Nest camera has stopped working. I have tried using the reset button. It doesn't chime. The green light just comes back on, but then turns off. The camera shows as unavailable or offline on the app.
@jonrrunge
Are you using the "factory reset" instructions, and NOT the "restart" instructions, which are both in the same Help topic? Sometimes customers don't press the reset pin long enough.
https://support.google.com/googlenest/answer/9252162
jonrrunge
jonrrunge
My Google Nest camera has stopped working. I have tried using the reset button. It doesn't chime. The green light just comes back on, but then turns off.  Doesn't matter if on charger or not.  The camera shows as unavailable or offline on the app.
@jonrrunge
Thanks for answering.  Yes.  I have pressed the reset button for 10+ seconds.  The camera green light comes on, but then turns itself off.   Attaching the charging cable does nothing.
@jonrrunge
My only other suggestion is to make certain you're depressing the reset pin with something like an unbent paperclip.
You could try contacting Support:
