12-12-2022 07:21 AM
So I moved from Colorado I purchased 3 google nest cams 2nd gen wired and used them for a year on wifi there, 5g and had no issue's at all. Moved to New York and I got spectrum, it says the router does 2.4ghz and 5g and I was able to attach one camera one time and it worked very poorly and then never reconnected, I created a new home in the nest app and deleted old ones. Now my issue is no cameras attach to wifi at all, I constantly get error C104 and sometimes others but haven’t seen them in awhile so can’t recall. Spectrum couldn’t help nor could Google support line. I am not imputing passwords wrong and constantly get that error code. At my wits end and would appreciate any help.
12-16-2022 08:23 AM
12-19-2022 06:45 AM
I’m having the exact same problem. Did you get it figured out? It seems like I have done everything. Anyone has told me to do and I’m still not able to connect.
01-05-2023 03:02 PM
Hello folks,
@David38 and @jaaron0530 aside from performing a simple restart, you may reset your Nest Cameras to the factory default. Remember that after the reset, all of your recorded videos will be deleted as well. Also, try restarting your WiFi network and your mobile phone. Don't forget to connect your mobile phone and your Nest Cameras to the same WiFi network. For example, both of them are on the 2.4GHz network.
I appreciate the help, Brad.
01-10-2023 12:55 PM
Hello everyone,
How's it going with your Nest Camera? Were you able to read the information I've shared above? Also, how did it go after the reset? We'd be glad to hear from you — We'd like to make sure everything is working.
01-11-2023 01:05 PM
Hi everybody,
