03-31-2024 03:41 PM
I’m having issues with my wired doorbell it will turn on but not connect we even reset our router but still nothing I have a battery one and it worked but my wired nest don’t
03-31-2024 04:08 PM
Hi Ryshrum,
Thanks for reaching out, sorry to hear that you're having trouble connecting your Nest Doorbell wired. Can you tell if the device was paired before? What is the color of the LED status light? How far is the Doorbell from the router?
You can also attempt these troubleshooting steps:
I hope this helps.
Sincerely,
Jonathan
04-03-2024 01:17 AM
It was connected before but had to redo it permanently and now all it show is a white light and when it says in your device blinking blue it will still be white
04-03-2024 01:20 AM
And the router across the room not far way from it at all
a month ago
Hi Ryshrum,
Thanks for keeping me updated. Sorry to hear the previous troubleshooting steps didn't resolve the issue with your doorbell.
I'd like to learn more about this behavior, when you get a chance please fill out this form. My team will reach out to you as soon as possible.
Let me know once you're done.
Jonathan
