12-16-2024 03:26 PM
I have a Google Nest Outdoor IQ CAMERA.
The Hex set screw is LOCKED (stuck) so how to gt QR code? or a code to set up the camera again?
12-19-2024 11:08 PM
Hi @dhaarn!
Thanks for posting in the community.
I’m sorry for the inconvenience that you’ve been experiencing with your Nest Cam IQ Outdoor. I can see that you need to set up the camera; it is already installed, and when trying to remove it from the wall to get the QR code, you noticed that the hex screw on the camera is stuck. Let me help you with this.
To set up your camera, you will need the QR code or the entry key. However, this entry key is located just next to the QR code. Then in this case I will suggest contacting a local technician to receive further assistance about removing the stuck hex screw. Once you have access to the QR code you can take a picture of it to use it in future scenarios.
If you have any other questions, you can keep posting.
Daniel.
