How do I replace my battery in a Nest door bell
bhb
Ashepherdson
You wouldn't replace it, but charge it via the port on the device.  There will do course be aftermarket mods eventually but I have not seen any guides for the battery version yet, only the older wired version, see below
https://www.ifixit.com/Guide/Nest+Hello+Battery+Replacement/131729
@Ashepherdson is correct, you would charge the device not replace a battery. Thank you for the help, @Ashepherdson!
Hey Folks.
