Nest aware (wired cam 2) - re-add familiar faces
amwalton89
I have the Nest camera wired (new version)
I have recently set it up, and we had facial recognition enabled and it worked fine. I accidentally deleted a face, and now i cant seem to add that person back. Whever they appear on the camera, it now flags as "person" with no way to change/ammend.
Anyone come across this before?
Rubes
If the camera is seeing the event as “person”, you should be able to tap on the “People” tab when viewing the live feed and from there you’ll see one or more unfamiliar faces that you can add to your photo recognition library.
@Rubes thanks for your help!
Hey Folks.
