01-08-2023 04:31 PM
I can disable the camera, but I don’t see a way to disable the floodlight after dark.
is the only option to cut the power with a manual switch?
01-09-2023 02:52 AM
01-09-2023 02:52 AM
01-09-2023 09:39 AM
Hi David,
I think your suggestion might work well. Is there a way to toggle this setting via a Routine?
Also, does this actually turn off the motion sensor electronics? My hope is it does, just like when I turn off my Nest doorbell the sensor itself is disabled. As a sabbath observer, this is important to me.
‘Thank you for replying!
-Joey
01-09-2023 10:49 AM
That I'm not sure of I'm afraid, but the floodlight certainly shouldn't turn on if that setting is turned off.
01-09-2023 01:40 PM
I'll give it a shot - thank you
05-23-2023 06:59 PM
Hi Edadev1,
I am sabbath observant as well and looking into the various Google Nest camera options (particularly wired doorbell and floodlight) were you able to deactivate the sensor altogether?
01-13-2023 02:15 PM
On a Nest Camera/Floodlight with all the settings turned on (high sensitivity), and with the camera motion sensor working fine and recording on the camera, is there a reason why motion wouldn’t turn on the floodlight? I can turn it on manually (through the Home app), but motion doesn’t seem to turn on the floodlight (even though like I said, motion does activate the camera…) Thanks!
01-13-2023 05:33 PM
Edsdev1, checking in — we hope you've got the answer you're looking for. Let us know if you have more questions in mind.
PogoBrian, let's see what's going on. When did it start happening? Have you tried turning off and on What turns on the floodlight settings in the Google Home app to see if that helps? Also, you can try restarting your Nest Cam with Floodlight to refresh the connection.
You can check out this link to Choose what turns on your floodlight.
I appreciate the help, davidking.
Archie
01-18-2023 09:17 PM
Archie
01-19-2023 04:58 PM
Hi Archie,
2 questions
if I disable the flood from triggering via the motion detector, set the brightness to 0 and I turn off the camera too, is the motion detection hardware fully turned off?
I do the above via a scheduled event and seems to work correctly. but I also schedule the camera to turn back on 2 hours after sunset and to keep the light off but brightness at 100%. When the event triggered it left the flood in an On state with brightness at 10%. Any ideas what I did wrong?
thanks,
-Joey
02-28-2023 08:56 AM
Just checking in to see how the conversation is going as I know it's been a minute since we last reached out on this topic. Please let us know if you have any further questions or concerns.
03-03-2023 08:59 AM
Let me know if you need anything from me, but I am just seeing how the conversation is going. We'll leave this thread open for a little longer for follow-up questions and concerns.
03-07-2023 10:13 AM
I wanted to pop in and see how things are going. Please let me know if you still need help. We'll leave this topic open for another 24 hours in case there are any follow-up questions or comments.
03-07-2023 11:11 AM - edited 03-07-2023 11:12 AM
Hi Brad,
also, I found a bug if I schedule the floods to motion detect again with 100% brightness , they sometime turn on with random brightness levels.
I was able to work around it by scheduling a second event right after that turns them off, in case they got turned on. Silly, but thought I should mention it.
Thanks!
-Joey
03-08-2023 08:42 AM
I appreciate your sharing your experience with us. I get where you're coming from, and I would love for you to share your feedback with us. We’re always looking for ways to improve, and appreciate you sharing. You can send it at any time using your devices, following the steps found here.
03-08-2023 05:53 PM
Hi Brad,
03-14-2023 09:24 AM
These devices are meant to work together, so my answer would be no, that generally isn't going to work if you do not want motion events to turn on the floodlight. It is built to do just that.
03-14-2023 07:52 PM
You misunderstand; I want to be able to fully turn the units off, esp. the motion detection, without powering them down physically.
08-01-2023 04:28 PM
So the answer here permanently disables the motion sensor for the floodlight. I'd like to be able to set up an automation so I can say "patio party" and it'll disable the motion sensors, then I'll have them by default turn the motion sensors back on every night after midnight.
I searched the script commands and couldn't find one that would let me toggle the motion sensor for floodlight, is there a way to request this api?
