I have lost the QR code for my nest camera for indoor
Phyllis303562
I lost the QR code for my nest camera for indoors so I don't know how to program it to my phone.
HELLO!!!
I'm up & running!
THANKS FOR ALL THE SUPPORT!
It was very easy after I got to the QR code!
13 REPLIES 13
Rubes
The QR code is typically found on the back or bottom of the actual Nest Cam. It can also be inside the battery compartment.m, if applicable.
Chulounv
So do I need to unscrew the 4 screws and open it that way cause I’m confused
sherriehill124
HI!
I purchased my NEST in 10/2020.
It was installed, but never connected to my phone. It all got put on the back burner, now... here I am.
I now have a new phone & router and everything is 'communicating', except for my NEST (because it was never setup)
I can't find my original box & paperwork.
I see from your answer above, how to find the QR code... HOW DO I GET THE DOORBELL OFF MY HOUSE TO SEE THE QR CODE?
Thank YOU!
The same pin (needle type) tool you use to open your SIM card/SD slot on your phone , you would use at the bottom of your attached doorbell to release it from it's holder. The qr code is on the back . It snaps right in and off.
Thank you, so much!
Thank you, for your input!
(Sorry, I didn't get any kind of 'notice' on your response!)
@Rubes thank you for your help!
Hi, Brad! Thanks so much for checking on me!
No, I still haven't 'resolved' it, but someone told me I can pull the bell off the house and the code
will be under it?
I just haven't had time (made time) to do it!
I'm putting it on my list for tomorrow.
Thank you, so much, for checking on me!
(If it doesn't work, I'll be in touch!)
@sherriehill124
Once you have a look, please let us know if you still need assistance.
sherriehill124
Brad, thank YOU! I will try to get to it, soon!
Just checking in to see if you still need assistance with this issue.  We'll leave this topic open for another 24 hrs in case there are any follow up questions or comments. Please let me know if you need further assistance.
HELLO!!!
I'm up & running!
Hey Folks.
I am relieved to hear that this issue is resolved! At this time, I'll go ahead and lock this thread. If you're still experiencing problems, feel free to start a new thread and we'll be happy to help.
