Installation 220v
Davidntfc
8A3BC7B4-08B4-4FF8-9714-10839D86622D.jpeg Could someone please confirm if my Nest Hello Wired doorbell is compatible with the above? If not am I returning it or have I options for installation. Thanks in advance
Linluvsbirda
Your best bet is to follow the instructions.  I set mine up a few years ago so I don't really remember but I do know the instructions were easy.  Also I have two video doorbells set up to one inside unit and it works great.
I apologize for my late response and thank you for all of your patience while waiting for a reply. I understand how frustrating your situation must be, and I would love to help however I can. I am no electrician, so I would honestly suggest that you contact Support for them to help you further with this inquiry. You can reach out to Support here.
Hey Davidntfc,
I wanted to check in and see if you managed to see Brad's post? Please let me know if you have any questions from here. I would be happy to assist, and ensure you are good to go.
Jeran
Hey Davidntfc,
Just checking up,
Jeran
