Motion recording
Rupsky52
How long does the wired nest doorbell record motion with the basic service, is it longer then the 10 seconds?
David_K
Hi @Rupsky52
In the Google home app, select the camera you want to adjust and then select the 3 dot menu in the upper right of the screen, select settings and then video. Here you can then set the maximum event length up to 3 min from the default of 30 secs.
