04-17-2024 12:36 AM
Need the width between the screw holes on the Mount plate for nest cam indoor outdoor battery (current model)
04-20-2024 10:56 AM
Hi Sharpe88,
Thanks for reaching out! I understand you're looking for the width between the screw holes on the Nest Cam (battery) mount plate. While the installation guide doesn't specify that measurement, here's the helpful article Install or mount Nest Cam (battery) which might have other useful information for the mounting process.
Let me know if that works!
Ivan
