09-10-2023 06:40 AM
Hi, before purchasing I wanted to check that Nest doorbells would be suitable for the set up I need. I'd like to install 2 battery operated doorbells for different doors, ensure no chime sound in the house - phone notification only (silent needed as dog goes crazy with the bell) and that both myself and my partner would receive notifications - 1 x android phone, 1 x iOS. Many thanks!
09-13-2023 02:31 PM
Hello christinabev,
Thanks for reaching out here in the Community. You can achieve this set up, just make sure the notification settings are turned on from the Google Home app. You may open the Google Home app> select your Nest Doorbell> Notification and turn it on.
Just a reminder, you'll receive the notification to your phone with the usual iPhone and Android ringtone and not the expected ding dong like the sound you hear from the Nest Doorbell itself.
