01-29-2024 04:07 PM - edited 01-29-2024 04:28 PM
After cold spell (-11 f) battery will no longer charge, unit is dead. Unit lost internet connection so i brought it indoors to warm up and charge. It will not turn on and will not charge. Tried restart and reset. Nothing works. warranty ended a month ago. Tried using the supplied wires to connecting directly to existing doorbell transformer (16v) and unit will not work. Can the battery be accessed to test/replace?
01-29-2024 05:22 PM
You’re probably gonna fill out a ticket, wait forever to be told your warranty expired.
01-29-2024 05:36 PM
Hopefully with all the similar issues noted by multiple customers, google nest recognizes a defective product and offers a fix or replacement.
02-02-2024 02:35 PM
Hello folks,
@jstarkfulda, thanks for reaching out here in the Community. The batteries in Nest Cam (battery) and Nest Doorbell (battery) have the following minimum temperature requirements:
At temperatures between -4°F (-20°C) and 32°F (0°C), the battery can still power your device, but it won’t charge. It may also drain more quickly than usual. At temperatures close to -4°F (-20°C), your battery may have less than half the life that it has in warm weather.
If the temperature is below 32°F (0°C) and the battery is low, bring it inside to a warm place, preferably at room temperature. The battery can start to charge slowly once its temperature rises past 32°F (0°C). It will charge faster when it warms up.
To learn more, you may visit our public article about, “Cold weather battery charging behavior in Nest cameras and doorbells”.
Thanks for answering, canosoup.
02-03-2024 07:55 AM
They won’t, I’m actually here because they won’t replace my 2 year old camera. When Nest was running the show, they would replace a broken camera no matter what.
Anyways, WYZE has great cameras at ¼ the cost and ½ price for the subscription. WYZE has an outdoor camera that rotates 360 for 36 dolars! 😂 cancel your subscription!
02-03-2024 02:31 PM
Hi canosoup,
We're sorry to hear if you're not able to get your replacement. Could you share your case ID here so that we can take a closer look at what happened.
