12-10-2022 06:06 PM
Just re-attached my doorbell via hardwire to power on my front porch. It was working fine yesterday. The White LED turned on, blinked for a few second, then turned off.
The doorbell still chimes via my chime in the house, it’s getting propper power. Any Ideas?
12-14-2022 08:48 AM
12-20-2022 09:32 AM
@GHOFF It's us again. I'm dropping by to ensure that everything is covered here. Were you able to read and perform what Brad has shared above? In case you have an update, you know where to find us.
I appreciate the help, Brad.
12-21-2022 09:35 AM
Hi GHOFF,
