01-28-2023 10:52 AM
I just wired up my 2nd gen doorbell. I checked the voltage at the doorbell and at the transformer and both are 14va. This should suffice as the box says 10va min, yet my doorbell is flashing a yellow light to indicate low power. What am I missing?
02-03-2023 02:44 PM
Hi Quinquilla,
Thanks for reaching out here in the Community and for sharing with us your concern. Try checking the voltage at the doorbell. Instead of at the transformer, you can check the voltage of the circuit at the doorbell with a multimeter. The compatible voltage is 16 to 24V AC, regardless of your transformer and chime. The requirements for the 2nd and 1st gen Nest wired doorbells: 16V AC to 24V AC and at least 10VA transformer and wired doorbell. Hit this link for more information.
02-06-2023 04:09 PM
I appreciate the help, Emerson.
Archie
02-07-2023 09:19 AM
Yes, as you can see in my question I checked the power at the doorbell and the transformer. Thanks though!
02-07-2023 12:38 PM
Hi Quinquilla,
@Quinquilla we appreciate you taking your time getting back to us and for sharing with us what you've done to resolve the issue. We’ll consider this one complete so let us know if you have other questions or concerns as I will be locking this after 24 hours. Feel free to start a new thread and we'll be happy to help.
Thanks for following up, Archie.
02-07-2023 09:18 AM
Thanks, no I got it. It was 14 VAC and min requirement was 16 VAC (though contrary to the instructions it did not work as a usual doorbell). I installed a new transformer which was not difficult and corrected the problem.
