01-09-2022 01:40 PM
I misplaced my magnetic mount for the Nest Battery Cam. Can I order a replacement?
01-09-2022 01:51 PM
Contact Nest Support as they would be able to answer that for you!
01-10-2022 09:24 AM
Thank you for your patience. If you are seeking a replacement, please first fill out this form so we can collect some important information from you. Once the form is submitted, you will have your case number. Please be aware that this thread will be locked.
