03-23-2025 09:14 AM
So brand new nest cams are not connecting to wifi network on my T-mobile gateway router. Spent an hour or more with Google support. They said could be faulty device, so I ordered new ones. Same issue. Called Google again. This time they say nest cams are not compatible with T-mobile routers if they are not wired! I don’t think this is right, and she just wanted to get off the phone. Help!
03-26-2025 02:22 PM - edited 03-26-2025 02:24 PM
Hi @Stevyang,
Thank you for posting in the community. I'm sorry to hear you're experiencing some inconveniences adding your Google Nest cameras to the Google Home app on your Wi-Fi network, even after contacting technical support. I'm happy to assist you.
Please provide the information below to determine why you cannot add your cameras in the app:
In the meantime, I recommend visiting the article Troubleshoot Nest camera and doorbell setup messages.
Please keep me posted. I'll be waiting for your response.
Anders
04-14-2025 05:53 AM
I sure wish someone could post a solution as I'm having the exact same problem. How can everything else connect find but this new nest cam is "not compatible?" MAKES NO SENSE! I've spend hours trying to get this thing connected with no solutions as of yet.
