10-20-2021 06:12 AM
Can the camera with floodlights be mounted horizontally under the soffit ?
10-20-2021 08:05 AM
Hope you are doing well! The Nest Cam with floodlight is only designed to be installed on vertical surfaces like a wall. It is not designed to be installed on horizontal surfaces because the downward facing angle would reduce the floodlight’s functionality by limiting the field of view of the PIR motion sensor (which triggers the floodlight when motion is detected). Hope this helps and we've also shared your feedback with our team.
10-25-2021 08:42 AM
Hey folks.
11-17-2021 12:59 PM
Hey Folks.
