Nest Cam with floodlight mounting bracket
Boulderrs
I received a preinstalled Nest Cam with Floodlight but it did not come with the mounting plate/bracket.  I have tried Google Support and they said the part is not available separately and via Google search....nothing comes up where to purchase only the mountain bracket.  Any ideas?  For reference here are a picture of the part.2022-05-17_11-32-56.jpg
7 REPLIES 7
Rubes
Only thought I have is third party marketplaces such as eBay. See if anyone is selling a used camera and purchase that to get the part. Very few options for this unfortunately, basically non-existent.
Boulderrs
Thank you Rubes, no luck yet searching eBay but I’ll keep at it.
SteveT1
I appreciate the help @Rubes. I wanted to check back in to see if you have other questions and concerns. Feel free to let me know.
Steve
I’m still looking for a mounting bracket so I can reinstall a Nest Cam with Floodlight but it did not come with the mounting plate/bracket.  I have tried Google Support and they said the part is not available separately and via Google search....nothing comes up where to purchase only the mounting bracket.
James11
I'm having the same issue, the camera is useless if the mounting bracket gets damaged or lost.  I can't find a replacement.  How does Google not make replacement parts so we can continue using their product?
Boulderrs
Thank you Aviles!  Unfortunately I am looking for a vertical mount (side of the house) and the link you shared is for a horizontal mount (under the eave).
