Nest Cam with floodlight (wired) Mounting Height
Nesgoda
I am installing the Nest Cam with floodlight (wired) in a new location. How high should it be off the ground? I can mount it anywhere between 12 feet and 25 feet. 2) It also has a motion sensor is there a recommended height for that?
Rubes
Anywhere between those heights will be fine but just keep in mind the motion sensor has a 25-foot range at 180 degrees. So the higher you mount the camera, the less sensitive the motion sensor may be for motion immediately below the sensor however it really won’t affect performance all that much at 12 to 25 feet height.
Personally, I’d mount it around that 12 foot mark. If you ever need to get access to the camera, I would think it’s much easier to get a ladder up to 12 feet.
SteveT1
I appreciate the help @Rubes. I wanted to check back in to see if you have other questions and concerns. Feel free to let me know.
Steve
SteveT1
We haven't heard any updates from you. I'll go ahead and lock this thread in 24 hours. If you're still in need of assistance, feel free to start a new thread and we'll be happy to help.
Steve
