4 weeks ago
I have just replaced the Internet Modem, which automatically changed the Wifi Connection. I can change the Wifi connection on the Google Hub Display but not on the two Cameras.
I followed online advice to delete the Cameras (Battery type) from the Home App and then add them back for setup with new Wifi. Whatever I tried, the Cameras will not connect to the Phone Bluetooth with Camera Setup Codes. I used the Camera Setup Codes (from the back of the Camera), because I do not have the Camera Barcodes. I have performed the followings without any success:
How can this issue can be resolved:
4 weeks ago
I can't tell from your post whether you performed a factory reset on your battery camera (to clear the old Wi-Fi settings).
Press and hold the reset button on the back of the camera head.
At 10 seconds, the status light will blink yellow four times, and you'll hear a countdown tone.
At 12 seconds, the status light will be steady, solid yellow while the camera starts the factory reset, and you'll hear a confirmation tone.
Release the button. Your camera will restore to its factory settings.
