07-28-2024 06:40 AM
I have a Nest Doorbell which detects people and cars 40 feet away and more from the doorbell without issues.
I just installed a Nest Camera Floodlight 12 feet high on a tree in the backyard and its motion detection is very limited (no more than 20 feet) even as motion is set to high in the Home App.
I am wondering if I should lower the camera to say 8 feet to make the motion sensing with higher range??
Or is the 12 feet height is not an issue as It would be a lot of work to lower the camera.
Thanks in advance.
07-31-2024 09:28 AM - edited 07-31-2024 09:28 AM
Hi todo,
Thanks for posting. I'm sorry to hear about the situation that you are experiencing with your Nest Camera Floodlight. But don't worry, I can help. In this case, you can try to move the camera to 8 feet and keep an eye if the camera can detect motion sensing.
Please let me know how it goes, I'll be waiting for your response.
Jenny
07-31-2024 07:38 PM
After few days of testing I realized that the closest distance from the Floodlight Camera to the area it is looking for motion is 55 feet - and now it does recognize motion pretty well.
I guess the camera is too far for it to recognize faces although it does recognize the dog as a animal.
You may close this thread thanks.
