10-05-2024 07:14 AM
How do you switch from 5G to 2G on the cameras? They worked better on 2G versus the 5G.
10-08-2024 12:58 PM
Hi Boatright86,
Thanks for reaching out to the community! I’d be happy to help by switching the band to 2 GHz. Help’s here!
In this case, it's recommended to connect the Nest cameras to the 2.4 GHz band. For now, there isn't a direct setting to switch between 2.4 GHz and 5 GHz networks on the Nest cameras. However, there are a few workarounds you can try:
After checking this information, you may need to perform a factory reset depending on the model of your camera and set it up through the Nest or Home app again. For reference, you can check out these articles: Restart or factory reset Nest camera or doorbell, and Set up and connect Nest camera.
For more information, you can see this article: Internet bandwidth and speed requirements for Nest cameras.
Please keep me posted.
Jenniffer
