03-29-2025 02:33 PM
I purchased a home that had the cameras already installed. How do I go about resetting these cameras and adding them to my account for usage?
03-29-2025 05:48 PM
Make sure the previous owner removed the cameras from their Google Nest app or Google Home app (as appropriate) while still on their Wi-Fi network, then perform a factory reset on each camera, and then reinstall them in the Google Nest app or Google Home app (as appropriate).
03-30-2025 06:54 AM
Thank you for your response. Do you know if your u can reset if the cameras were not reset by the previous owners?
03-30-2025 07:23 AM
Some 1st gen Google Nest cameras and doorbells can only be factory reset by removing them from the Google Nest app by the device's owner.
See the second link I provided earlier for details on factory resets. (Be sure to scroll down past the "Restart" instructions.)
04-01-2025 03:20 PM - edited 04-01-2025 03:20 PM
I think I am out of luck. Previous owner passed, not access to him or the old network.
But I thank you very much for your response!
04-01-2025 03:56 PM - edited 04-01-2025 03:56 PM
SOME of the 1st gen cameras CAN be manually factory reset; see the specifics for each camera.
For those that cannot, you can wait until the previous owner's Nest Aware subscription period expires (up to 60 days); see this Help topic:
https://support.google.com/googlenest/answer/9249728
