09-11-2024 01:25 PM
I have a google nest doorbell (Gen 2) and no matter what combination of wiring I try, it does not ring the chime properly. The chime vibrates but does not ring. If I don't install the connector, the chime rings properly but when the doorbell is not in use, I can hear a faint pulsing sound come from the chime box.
My current setup is that I have the grey wire from the connector going to "T" and the white wire from teh connector going to "1".
I would upload a photo if I could!
09-11-2024 07:39 PM
Hello, so you definitely want to get the puck connected and working properly. Other wise there is a chance you can burn out the solenoid inside the doorbell Chime. Plus you don't want to hear that annoying buzz all the time.
Here is a video that shows you how to connect the puck. If it doesn't work try reversing the puck wires.
https://www.youtube.com/watch?v=c8MW2TsWKmk&t=162s
If it still does not work the double check the power ratings on the transform that drives the doorbell. It must be 16-24 VAC (for N. America) and also be rated for 10-40VA. If it isn't then you probably need to replace it. They are available at Home depot or Amazon.
Hope this helps.
