Nest Doorbell (Battery) Live view not working consistently
RH_
Hi all,
Yesterday I've bought the Nest Doorbell (Battery) and installed in right away. While testing the doorbell I've ran in to an issue with the live streaming. Sometimes the connection is setup right away, and sometime I've nog been able to connect to the Nest Doorbell.
The Wifi connection at our front door is good, the throughput is around the maximum that is possible on a 2,4Ghz connection. The app on my iPhone is up to date, and im getting a bit lost what the cause of the problem is.
Does anyone have similar issue with the Nest Doorbell and an iPhone?
2 REPLIES 2
James
We just wanted to follow up one more time in case you hadn't been able to solve your problem yet. If not, we'll go ahead and close this thread in another 24 hrs.
Thank you,
James
