01-05-2024 01:51 PM
I received a Nest Doorbell (Battery) for Christmas. Installed it and connected to my iPhone with the Google Home app. Everything appears to be working correctly.
The last thing for me to do is have the doorbell ring audibly inside the house. I'm not sure what the easiest way to do this is. The Nest Doorbell (Battery) is the only piece of Google hardware that I have. My devices are Apple products which has the Google Home app running on them.
Would I be able to place a Nest Mini in the house and connect it to the Nest Doorbell (Battery) via the Nest Home app? I'm thinking this might work but can't find anywhere to confirm. Or is there a better way I'm not aware of?
Thanks, Leon
01-05-2024 03:28 PM
Yes, you can get a Nest Mini, install it in the same Google Nest "home/structure", and turn on "Visitor announcements" for your doorbell:
https://support.google.com/googlenest/answer/7672451
We get such announcements on our Nest Hubs and Nest Mini.
01-05-2024 03:28 PM
01-05-2024 08:17 PM
Thank you for the prompt reply.
Nest Mini has been ordered and will be here tomorrow.
01-10-2024 02:31 PM
@Leond60, thanks for reaching out here in the Community. How's it going? Were you able to add your Nest Mini and enable the Visitor announcements? In case you have an update, you know where to find us.
01-11-2024 04:18 AM - edited 01-11-2024 04:19 AM
Thanks again to MplsCustomer and EmersonB for the follow up.
The speaker arrived, was easy to setup and it works.
I do have one question though, The speaker sounds a chime when the doorbell is pressed and a voice announces that the front doorbell has been pressed. Is there any way to keep the chime sound but lose the voice announcement?
01-11-2024 07:59 AM
There is no option to get just the chime sound and no voice announcement with "Visitor announcements", though customers in this forum keep asking for it.
01-12-2024 02:39 PM
Hello Leond60,
I appreciate the update and we're glad that it's working as intended. To answer your question about disabling the voice announcement, that feature is not available and that makes sense. I'd suggest you send yours with our Send Feedback form to let the Google Engineering team know about your concern. While they won't respond directly back to you, this is the best way to let them know about this.
01-13-2024 03:34 AM
Thanks again MplsCustomer and EmersonB.
I will send feedback as I see this as a critical shortcoming that could be easily remedied.
Funny how in our age of sophistication and automation, something like having the option to have a simple chime ring inside the house when a person pushes a button outside is undoable.
01-13-2024 04:44 PM
@Leond60, thanks for sharing your feedback with Google Nest, as this is the best way to get your thoughts and feature requests to the people who can make changes. Feel free to reach out or visit our Help Center if you need to fix a problem with a Nest camera or doorbell.
I appreciate the help, MplsCustomer and Emerson.
Lance
