11-04-2023 08:24 PM
Hi
I have just set up Nest Doorbell (Battery) along with Nest Hub.
The doorbell chimes outside but no sound comes through to the hub
It is connected to the hub as I can see the video and I can even speak to the person but it doesnt tell me/notify me when someone rings the doorbell.
I have troubleshooted the following:
1. Both devices at located at the same location on Google Home
2. They are both on the same wifi network
3. Doorbell visitor announcements are on
4. Software is updated on both
What else can I do to make the doorbell chime on the Hub inside so we know someone is at the door?
Thanks
11-05-2023 08:40 AM
Hello, I'm an end user like you. It has been working fine for me for a long time. I have the Nest HELLO doorbell and Google Hub 2. The only thing I can think to try is cycle the power on both the doorbell (I know it is a pain to remove it and disconnect the wire for about 60 seconds) and the hub as well.
Otherwise you can open a support ticket and fill in the information and you will be able to connect by phone with an actual Google Tech person...
11-05-2023 08:32 AM
I have the same problem 😕
11-05-2023 08:40 AM
11-10-2023 10:11 AM
I think you failed to fully read the question. This user has a battery powered doorbell, it is not on a hardwire. I am also having the same problem.
11-21-2023 04:23 AM - edited 11-21-2023 04:24 AM
Same problem here, did you get it to work?
11-24-2023 02:27 PM
Same problem here, live video does come up on the hub when doorbell button is pressed - but no sound whatsoever! C'mon Google!
11-24-2023 04:19 PM
Hmmmmm, maybe this? go into the Google Home app and select the HUB device. Click the GEAR in the upper right corner and then click on NOTIFICATIONS & DIGITAL WELLBEING. Make sure that DO NOT DISTURB is NOT turned on.
