Nest Doorbell not Connecting
Pat7
Had the doorbell up and connected but then had to change our modem (with Bell). Now it won’t connect to wifi. Tried all of the suggestions and nothing works
@Pat7
Generally, it's not easy to update Wi-Fi settings on Google Nest's devices, which is why they recommend, when getting a new router/modem, to set the network name (SSID) and password to the same values used on your old router/modem. If you can't do that, then generally you need to do a factory reset on your doorbell.
This is Google Nest Help's page on connecting cameras and doorbells to a new Wi-Fi network:
https://support.google.com/googlenest/answer/9223711
Juni
Thanks for the help here, MplsCustomer.
Pat7, I hope you've got the answer you're looking for. If you're still in need of assistance, please let us know, as we would be happy to answer any questions you may have.
Juni
Dan_A
Dan
Dan_A
Hey there Pat7,
Dan
