08-05-2024 07:28 PM
We have had our nest cam with floodlight installed since 2021 and it has always worked. A few weeks ago we noticed that the actual lights started flickering intermittently, and now the light will not turn on at all. A power reboot will fix it for a short period of time then it will stop functioning again. The camera is unaffected. Any thoughts on a fix?
08-08-2024 10:26 PM
Hi @Amandaengborg,
It seems you're experiencing intermittent light failure with your Nest Floodlight while the camera function remains unaffected. This suggests a potential issue with the floodlight's electrical components or the connection between the floodlight and the power source.
What I can suggest is:
Check Power Connection:
Inspect Floodlight for Damage:
Update Firmware:
Additional Tips:
Remember: Always prioritize safety when working with electrical equipment. If you're unsure about any of these steps, it's best to consult a professional electrician.
By following these steps, you should be able to diagnose and resolve the issue with your Nest Floodlight.
I’ll be waiting for your comments.
Josh.
