12-10-2021 06:52 AM
Last week I have received the Nest Hello Doorbell (battery) powered. I removed the old button (bell) and installed the device smoothly. Because there are some extra options when you power it using the bell transformator, I later on installed the Doorbell on the auxiliary power. (8W transformator/ 1A). This worked fine, when I checked the settings the doorbell was externaly powered. So far so good. But after a couple of days, the doorbell was switching back to batterypower. The percentage battery dropped down to 61%. Contacted google support, the advice was to reinstall the application on Google Home and then choose external power (instead of battery power). That worked, for a couple of hours unfortunaltely. The doorbell is again back to battery power.
I want to use the external power because it also is connected to a mechanical gong. This makes a much more louder sound than the Google mini. When a person presses the doorbell I mostly miss it because the sound on the mini is too soft. I can turn it louder, but when my family plays music they turn the volume down, and the bell sound is very weak. I also find no settings in the home application to make a louder volume on the mini when somebody rings the bell.
The reinstall the application every couple of hours is a workaround, but not a good one 🙂 Maybe the auxilairy power has nog enough power (1A / 8V)? Or maybe the cold temperatuur outside (2 degrees Celsius)?
Before I forget I checked all the cables with a universal voltage device and they are ok.
12-29-2021 07:46 AM
Got exact the same thing. Did you find anything?
12-29-2021 11:29 PM
What I found out at the moment is this: The Google Nest Doorbell (battery powered) can be used with a 8V connection. The transformer I am using (which is a quite common one in Holland) gives 8V volts, however it supplies 8VA. The doorbell uses a little bit more than 1A, say 1,25A so you need a transformer which supplies about 10VA (or more). It is possible to replace the transformer with a 12V or higher one, but then you also have to replace the ringer (which now uses 8V). Sending a higher voltage to the doorbell could ruin it. This is my theory, I didn't have time yet to prove it. Proving it, means bying a 10VA or more transformator which suits in the same socket as the previous one. To be continued....
12-29-2021 10:53 AM
12-29-2021 11:30 PM
Please see my remarks above. Is it correct that 8VA is not enough to power the Google Nest Hello Doorbell (battery powered)?
01-24-2022 11:34 AM
Hey Folks.
01-06-2022 04:42 AM
I have a TS8/8 SWH transformer. With 8V and 1 A. So is this the actual problem? What transformer do I need to make it work? It's still kinda strange it worked for like 4 days, and now it barely works.
01-19-2022 10:16 AM
Just checking in to see if you still need assistance with this issue.
01-21-2022 04:25 AM
Yes I still need help!
01-21-2022 09:22 AM
Nest Doorbell (battery) can be powered with wires delivering 8 - 24 V AC, and at least 10 VA, 50/60Hz, worldwide. I will state now, I am not an expert at all when it comes to wiring and electrical work. Have you tried to test using a multimeter yet? If so, what are the readings?
