05-06-2024 02:07 PM
I have had two Nest Outdoor Battery Cams for a few months. One of them unexpectedly stopped working. I try to reset and it goes white light then to green light but the google home app is not finding it. So I tried a hard reset. It will not do a hard reset. No matter how long I hold down the reset button it never makes the reset sound or goes to yellow. It just will go to white and then eventually to green. Help!
05-06-2024 04:33 PM
Is it possible that your paperclip or thumbtack isn't keeping the reset pin depressed?
We've had a battery camera for over 2-1/2 years, plugged in with the optional power cable, but we haven't had to reset it.
You could try contacting Support:
