11-24-2022 08:57 AM
Hi-
My Nest cam suddenly quit working, indicator light will not illuminate, conducted a factory reset and removed/readded camera and still will not connect. Any other troubleshooting tips? No other issues with my other nest cams or doorbell (all on same network).
11-24-2022 11:46 AM
You could plug and unplug the USB connection several times to make sure the problem is not a poor electrical connection, or swap the power cables with another camera if you happen to have another Google Nest Outdoor Camera.
Is the camera itself unaccessible in the Google Nest app? That is, it's not just the status light that's failed.
I've seen a few other posts about the outdoor camera or the IQ camera just dying after a few years. Ours are all 2-3 years old and still working.
11-28-2022 07:19 PM
LAFOSTER, I’m sorry to hear you’re having trouble with this. No worries, we'll check this out. Were there changes made with the setup, settings, and/or app of the Nest camera? Are you using the USB cable and adapter that shipped with the camera? Is the Nest Cam Outdoor’s cable securely connected to the power adapter? Try to push and twist the USB connector into place. Then, plug the adapter into a power outlet. Also, are there any kinks or frays in the cable?
Archie
12-01-2022 09:59 PM
Archie
12-02-2022 11:48 AM
No changes made, we had a brief power outage and all cameras and devices reconnected with the exception of this camera. I deleted from the app and attempted to add the device back and it keeps stating device not found.
12-05-2022 05:27 PM
Hi LAFOSTER,
Gotcha — thanks for sharing that with us. Could you try connecting your camera to a computer using a USB cable to check if the status light would come up and let us know how it goes?
I appreciate your help here, MplsCustomer and Archie.
12-06-2022 05:32 AM
Status light comes on! Appears to be a bad power adapter - any thoughts on how to replace?
12-06-2022 09:27 PM
Gotcha — thanks for isolating that. Let's check — could you fill out this form and let me know once you're done?
12-07-2022 11:50 AM
Form submitted! Thank you!
12-07-2022 12:49 PM
Hi LAFOSTER,
We got your form — thanks for filling it out. Our team will reach out to you via email to further assist you. If you have any questions or concerns, feel free to create a new thread as I will be locking this thread after 24 hours.
I appreciate the help, MplsCustomer, Archie and JT.
